brake manual
I recommend picking up the Dodge Ram SRT-10 Service Manual for your truck. I don't have a part number, but check with your local Dodge/Chrysler dealer. It's 8400+ pages; get it on CD if you can. LOL
It's worth every penny.
to remove CAUTION: Never allow the disc brake caliper to hang from the brake hose. Damage to the brake hose will result. Provide a suitable support to hang the caliper securely.
Raise and support the vehicle.
Remove the tire and wheel assembly.
Compress the disc brake caliper.
Remove the banjo bolt (1) and discard the copper washer .
Remove the caliper mounting bolt (3).
Remove the disc brake caliper (1).
to install
NOTE: Install a new copper washers on the banjo bolt when installing
Install the disc brake pads, anti-rattle springs (2) and pad retaining pin (3).
Install the disc brake caliper (1).
Install a new caliper mounting bolts (3). tighten to 176 N·m (130 ft. lbs.).
CAUTION: Verify brake hose is not twisted or kinked before tightening fitting bolt.
Install the brake hose (2) banjo bolt (1) with new copper washers to the caliper. Tighten to 27 N·m (20 ft. lbs.)
Bleed the base brake system, (Refer to 5 - BRAKES/HYDRAULIC/MECHANICAL - STANDARD PROCEDURE).
Install the tire and wheel assembly, (Refer to 22 - TIRES/WHEELS/WHEELS - STANDARD PROCEDURE).
Lower the vehicle.
I recommend mechanics gloves and have some brake spray cleaner around. If you haven't worked around trucks much, every thing is heavy and takes a strong hand.
The responses are really good shit! Some strong tech input here! Thanks friends, never tried this, but feel confident now (except for the strong hands stuff).
