Stanimal
if there is ANYTHING of the bolt left, you can try this. do what you did with the dremel on the bolt itself, cut a grove for a screw driver. go down to your local staples or office max and get a can of their keyboard cleaner. It is just pressurized co2. Take that and spray the whole can on the bolt itself. What this will do is shrink the bolt away from the aluminum and loosen it up and hoefully the screwdriver will easily take it out. I have done this a dozen times worked 75% of the time for me. Hope this helps
