BlackMamba50
#10pistonkilla
My cam arrived today. Any cam God's out there have any comments? This cam will be combined with Street Strikers 75cc with compression bumped up with the thinner head gasket.
Not bad specs! Should be a nice power making cam. Makes sure and install new springs, pushrods, and honestly with the duration and lift I wouldn't hesitate to add new slow bleed lifters to get the full power. Now, it's going to be a midrange up to redline power maker, so should be nasty with strikers
Enjoy!!
I would verify the push rod length once the heads are on. Looks like a great build!!
What length Pushrods do you have .those cam specs are real close to the stage 2 Crower cam I had at first on my strikers ,,after zero lash 3/4 turn on adjusted till you get them pumped up then you may need to go back and give them another 1/4 turn ,slow bleeds are not as forgiving as own lifters
CV Racing 4130 CV7600.
7.600"
