Cant get Spiders in!
sinus19
Is there a trick to putting in the upper spiders gears in?? I already have the side gears in. The back of the upper gear hits the case When i try to "roll" one in. I try to wigle it in as i rotate the axle but it only rolls in 1/4 of the way and gets wedged against the case.
I think i need to compress the clutches?
Yes i did.. got the kit from JTSVP. How do i compress the clutches?
Ok new clutches are gonna be TIGHT. I made a tool to compress the clutches from the inside out of some all thread and washers. I took an axle out and bolted it to the spare tire to use as a stand. Compresst he clutches then spin the diff on the axle a few times then tighten some more then repeat until top gears fit
Would i loose the pinions back lash if i take out the carrier?
Well do. Thanks bud.
Yea they are lol. Especially when you dont have a carlift
