I have the Bassani Headers with JMB catless mids. The bolts that hold the mids to the headers keep loosening....I can drive a 100 miles and the bolts will turn 1-3 turns before tightening...........any suggestions?..
Hamrhead said:I'm assuming there are bolts and nuts, so have you got washers under the nuts?:dontknow:
If they do not use nuts, is there any way you can add them?
(I had Belangers, so I'm not sure about your setup??)
sleeper said:Thats another great idea. Or you can just drill a hole in each bolt head. Stinkers idea is the easy way.
Stinker said:find some safety wire washers, used them a ton on bikes , comes in all sizes, put under the nut, then bend the tab and wire the tabs together int he direction of tightning
http://www.solomotoparts.com/catalog/Lockhart-Phillips-Safety-Wire-Washers-p-22654.html
sleeper said:Before you try to fix. Go buy all new fastners and lock washers. Grade 8.
505'sFastestViper. said:stinker on a motorcycle iwant pics like yesterday!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
kyle's srt10 said:Did you use lock washers:dontknow:
