Tooloe said:Completely Fill the Can WIth Steel Wool?
Filled but not packed.....and Tony this is not a fix to the problem but just to help stop blowing oil everywhere....makes a mess.....
My bad sugarTNVIPER said:Filled but not packed.....and Tony this is not a fix to the problem but just to help stop blowing oil everywhere....makes a mess.....![]()
JTS VENOM PERFORMANCE said:My bad sugarnow if thats the case, I have used, and I know this sounds strange, but it reallly works well, but if you go by lowes, the thick stuff used for vents and air vents in the house that you use to take allergenics out of the air? looks like the stuff you use in fish tanks I think, but that stuff will def keep it from flying out, the only problem with it was you would have to keep an eye on it and change it out often, best deal is tho, its cheep
my aplogies oh large one:aetsch:
FSTJACK said:Normally a leak down test is done with a regulated 100psi of air.
Did you use a one or two gauge leak down tester ?
bigike said:2 gauge
bigike said:Yes, someone said that isn't a good measure because the pressures are so low. I did my test as per the instructions and only had 2%
