Cudajon
My check engine light was on and threw the code P 0320, it happened after I filled up, and I think it was because of the gas cap. It turned off after a little bit. Anyone know what the code says?
No crank reference signal at PCM.Cudajon said:My check engine light was on and threw the code P 0320, it happened after I filled up, and I think it was because of the gas cap. It turned off after a little bit. Anyone know what the code says?
Yeah i'm running with one of those at the moment,wtf does it mean:dontknow: :dontknow:JRSVIPR said:No crank reference signal at PCM.
Other than a loose connector,I do not know.Maybe one of the guru's will chime in.Michael from the U.K. said:Yeah i'm running with one of those at the moment,wtf does it mean:dontknow: :dontknow:
Thanks Robert,How you doing bro?TheMoparConnection said:all of you 04's,,, there is a flash for your pcm to take care of that check engine light with code p0320... just take to your local dealer... flashes are covered under warranty for 8yrs/80,000 miles... make sure you dont have a stageII installed when they flash it..
Bone said:Ya got no crank!
