Kevan
Hey folks.
After finding out that ALL lowering kits for the SRT-10 are so poorly engineered with questionable (at best) materials and components, I've decided to have *CORRECT* lowering blocks machined.
The blocks are going to be SOLID 6061 T-6 billet aluminum, MACHINED (not extruded) to proper OEM specs and for a PERFECT fit.
These are also designed so that the rear suspension components align correctly and work properly (unlike every single other lowering kit out there).
These will ONLY work with SRT-10 rear ends. They will NOT work on regular Ram trucks.
And for those that require the bling-bling, the blocks will all come with "SRT-10" *machined* into each side!
If you want something custom machined into the sides, let me know and I'll see what we can do for this test run.
Size Options:
1.5"
2"
3"
4"
I do not want to become a vendor, so if these get past the "one-off" status, the blocks will be offered through an approved vendor.
I am NOT doing this for profit. I am doing this to help fellow SRT-10 owners that have or want to lower their rears do it correctly and so that their suspension works as it should. I only want to get costs covered and I will gladly pay for my own set of blocks.
These can be cut, packaged, and shipped VERY quickly (within a week, or whenever the check clears...heh heh). There is NO WAITING and NO BACKORDER BS.
If it helps, these are 100% Made In The USA. Machined by guys named Bill and Rob and Derrick who live here in Ohio.
The aluminum is also from the US.
Of course it all comes down to quantity: the more ordered, the cheaper the individual sets will be.
I have (2) confirmed pair (Kevan-1.5, Greg-2) so the price is starting to come down.
Now, 3" and 4" blocks are slightly more expensive, but again....quantity rules the road.
Example: Single pr. of 3" blocks would be $522, and a single pr. of 4" blocks would be $546.
Like the chart above, the more we get cut, the cheaper they become per unit.
I would be happy to post the PDF quote from the machine shop or the other component receipts if anyone would like to see them. Let me know.
In addition to the blocks, you will probably need U-bolts (unless you already have longer ones from a previous lowering kit).
I'm still working on a good source for those and will get it posted soon.
There's also a threaded stud and a set screw for each block that I'll be sourcing over the weekend. It won't be much....just a couple of bucks (or less).
Everything will be Grade 8 or 18-8 Stainless Steel.
I'm not screwing around with this stuff. There is no "cheap" version of this.
Shipping will be via USPS with only ACTUAL shipping costs charged.
I'll have the CAD drawing up this evening.
That might help with those on the fence about this.
I'm not sure quite how to do the orders for this initial run.
I need a list of COMMITTED people, and the sizes they desire.
I might do some type of a deposit too....just to make sure I don't end up with 10 pr. of 4" blocks.
Please post here or send me a PM or email (kevan[at]jemfest[dot]com) with your commitment and what size block you would like.
Size Options:
1.5"
2"
3"
4"
Code:
QUANTITY---DESCRIPTION----UNIT PRICE------AMOUNT------PER VEHICLE
6............ea............$122............$732............[B]$244[/B]
8............ea............$105............$840............[B]$210[/B]
10...........ea............$95.50..........$955............[B]$191[/B]
16...........ea............$81.............$1296...........[B]$162[/B]
20...........ea............$75.75..........$1515...........[B]$151.50[/B]
