Clutch Fade after WOT
Discussion in 'General Discussion' started by Houb, Apr 26, 2020.
Car Parts
  1. Houb
    Houb Member Supporting Member
    34
    Dec 1, 2016
    Hi guys,
    Having issue with clutch fade after a pull at WOT for a while, tried flushing to high temp brake fluid and notice clutch line runs kind of close to Cats, but problem persists.
    Due to the Covid pain in the ass I don't have a lot of money or resources at my disposal being based in Dubai.
    Was thinking of making a heat shield for the line but would like someone to explain WHY it happens, before I make one, as changing to high temp fluid didn't really help that much so would like someone confirm it is heat based before just throwing money at getting the Viper Upgrade.
    *I used the search function and got the same issue but no answer*
    Thank you all in advance!
    Stay safe
  2. rottenronnie
    3,109
    389
    Jul 4, 2006
    Calgary, Alberta
    Hello Houb:
    What do you mean by fade?
  3. rottenronnie
    3,109
    389
    Jul 4, 2006
    Calgary, Alberta
    If you are talking about the clutch pedal getting soft, you will need to repair/upgrade your clutch hydraulics.
  4. FlaglerSRT
    FlaglerSRT Full Access Member
    50
    Jan 3, 2014
    Or is it begininng to slip afterwards? Almost sounds like the clutch is starting to go and cant hold the power.
  5. Houb
    34
    Dec 1, 2016
    Hey thanks for the replies.
    Clutch isn't slipping, only after being at high rpm for some time I press the clutch to shift up and it feels squidgy < not a technical term I know... I can still shift but engagement point feels like it moves much closer to the floor.
    If I shift to neutral and pump the clutch a few times it feels fine again.
    I hope this helped to understand.
    Again, thanks in advance for any advice you may have.
  6. rottenronnie
    3,109
    389
    Jul 4, 2006
    Calgary, Alberta
    You will need to rebuild the clutch hydraulics either back to stock or (suggested) - with one of the available aftermarket kits.
  7. Houb
    34
    Dec 1, 2016
    Thanks buddy. Any idea what causes the issue?
  8. rottenronnie
    3,109
    389
    Jul 4, 2006
    Calgary, Alberta
    Just the fluid leaking past the master cylinder seal.
  9. Kiwi SRT10
    Kiwi SRT10 Active Member Supporting Member
    285
    180
    Dec 16, 2019
    New Zealand
    Mine does exactly the same thing and it is like the thrust bearing being pushed away from the pressure plate fingers giving you a half pedal. if I rest foot on clutch pedal lightly it stops the fluid being pushed back to master cylinder then it works fine
    I am going under the truck today to see what is going on. Maybe pressure plate fingers at uneven height, may need replacing. That's what it was 40 years ago when I was a young mechanic. Things have changed since then. I will be investigating this problem
    AMS3 likes this.
