While, my platform differs from you guys, i can give a little insight and opinion. I've been running a spec 3+(without the easy pedal option) for 3-4 years(since i did my viper spec t56 swap). I'm going to continue using the gen 2 viper car hydraulics(master and slave). I am a firm believer that OEM is more reliable and since it's a PITA to address a problem. Reliability is what i want.
On that note, i just ordered a McLeod RXT clutch. I was tired of my Spec 3+'s very hard pedal. I'm probably close to 800tq(over 700rwtq) or over that and it holds fine on slicks at the track but im done with it. It also chatters on take off if i dont give it a lot of rpm. I do fine it's off/on as well now that you guys mention it. I just thought it was due to my unique swap or crap driving.
Ill be dropping the trans this weekend on jack stands and a Harbor Freight trans jack. It's not hard, just a little timing consuming. Ill be going back with the cheap dextron 3 trans fluid from Orielly.
I also have to take the tail section off and redo the gasket since it has a very slow leak. Hopefully it's just undoing some bolts and it's off and is easy to put back on.
