Thunderbuddies
Member
Ok. My 04 RC has been losing clutch pressure at very random times. Sometimes I get into it and there is no clutch pedal pressure. When this happens, I cannot get the truck into any gear. It can be very embarrassing at a stop light!
Other times it seems to be there. I have no visible leaks, and the fluid is always a little low when checking. I have bled the clutch numerous times, but it only seems to fix it for a few days. I have noticed it seems to be much worse on very cold days. On warmer days, I might have to pump the clutch a little at start up, but once I have pressure, I can drive all day with no problems. The master cylinder seems to be fine. I have checked the floor around the clutch pedal and I don't feel or see any leaks. I'm thinking it could be leaking via the slave cylinder into the bell housing. My next step, Before replacing the slave cylinder, is to try one of the Phoenix Reverse Bleeders. Anyone have any thoughts or opinions?
