chaynick
Do you guys know where i can get a new shim in case they lost mine (what's probably happened)?
Your clutch wont totally disengage and you will smell clutch burning during high rpm shifts.
if that's the case, you have a problem.
clutch should be on or off.
the only time you will smell clutch is if it's slipping - leaving a redlight, pulling into a awkward space, or slipping during a drag race.
if you smell it during daily driving, it's wrong.
without the shims the release bearing would be to far back. wouldn't disengage. the problem is that the release bearing isn't letting go completely. maybe to much shim.
Take it back to who ever installed it all and let them know something is wrong. Hate to have something fly apart under there!!
Thanks. The truck is going back to the shop next week. I'm assuming the clutch is damaged to some degree. If I decided to go with the new clutch is it worth it to upgrade to Spec Stage 2+ or Stage 1 will be enough for my application (stock)?
