coil spring
Ironhead
h-town
can you check to see if the front coil springs for a 96 to 2001 desiel 2500 2wd are the same as ones for a 8.0 v10 2500 2wd ,,
i was given a new set from a deiesl 99 2500 ,,and since im doing the ball joints and these springs are brand new i thought i would us them ,,,thanks
there should be a tag on the new springs with a number.. that would help out a lot if you had it...
edit.. there are 23 different springs I either need the vins for both vehicles or the tag numbers
Tag on springs is 52039074,,,the truck they might go on vin # is
1b7kc23w4wj199598
is there any way i can find out what rearend i have in this ,,or what was sold in it ,,,i think the gears are 3.55,s and has a posi loc in it but not sure thanks
