Common problems with the RAM SRT-10... Please list them here.
Discussion in 'General Discussion' started by energetic, Jun 22, 2006.
Car Parts
  1. eddie102870
    eddie102870 Active Member Supporting Member
    10,008
    May 22, 2006
    Alabama
    blakewilder find you a good ac shop and have a vacuum pulled on your ac make sure the right amount of freon is in the system too much or too little causes it not to cool properly i did it and mine does a lot better.
  2. cummin4u
    cummin4u Full Access Member
    111
    Jun 26, 2006
    Silver on black wheels :rock: :rock:
  3. Venom Power
    Venom Power Full Access Member
    11,286
    May 18, 2006
    Houston, TX
    Lemmie see.... On my '04:
    1. At 9,000 miles the front right side cat got stopped up and caused the passesnger side exhaust manifold to glow. Warranty work.
    2. Amp stopped working at around 13,000 miles. Got too hot due to poor ventilation. Screw the warranty, I put in a 2,880 watt system.
    3. Throttlebody position sensor took a crap at 14,999 miles. Quick warranty fix.
    4. I made sure I will not have problems with the harmonic balancer before the problem strikes at 9,000 miles.
    5. No problems with pedal nubs.
    6. Rear tires could not keep rubber on them at first.
    7. Squeeky clutch pedal. Started around 8,500 miles.
  4. azpyroguy
    azpyroguy Full Access Member
    2,089
    May 18, 2006
    Beyond the Sun....
    Mine went it for a front end alignment... dunno how it happened.. I never hit any holes, etc.. I noticed it was pulling to the right, and was getting some scrubbing on the front tires. They fixed it under warranty.
    My passenger side A/C is not so great.
  5. DJCHEROKEE
    DJCHEROKEE Full Access Member
    1,218
    May 23, 2006
    MINE IT'S PULLING TO THE RIGHT TOO.....:mad:
    FIRST I TOUGH IT WAS THE BRAKES BUT ....NOW IT DOES ALL THE TIME...
    I DON'T HAVE PROBLEMS WITH THE A/C.... YET... I HAVE A REMOTE START SO ...WHEN I GET IN THE TRUCK IT'S ALREADY COOL DOWN....
  6. Texas Yellow Fever
    Texas Yellow Fever Full Access Member
    8,086
    Fayetteville, Ark.
    The only issue I've had with mine I guess is the loud pedal sticks to the floor once in awhile....it seems to happen most often when there's a Vette or an L Truck beside me, but sometimes, it just happens for no good reason at all...other than that, everything else works just fine...:burnout:
  7. azpyroguy
    2,089
    May 18, 2006
    Beyond the Sun....
    They did not tell me how far it was out.. but they had to put it on the rack 3 times to get it right... so it must have been out quite a bit... I found it strange it only had 2000 miles on it!
    You might want to take yours in to have it checked out...
  8. DJCHEROKEE
    1,218
    May 23, 2006
    YOU RIGHT.... I WILL HAVE TO TAKE HER IN.......
    (HERE WE GO AGAIN IV BEEN THERE BEFORE WIHT MY 2004 HEMI..... TO BE EXACTLY 12 TIMES IN 2 YEARS BUT THATS ANOTHER STORY)
    MINE START DOING IT AT AROUND 2000 MILES IT HAS NOW 2800....
    THANKS FOR THE ADVICE... TAKE CARE.
  9. milkmanedi
    milkmanedi Full Access Member
    81
    May 22, 2006
    insurance is pretty high
  10. energetic
    energetic Full Access Member
    133
    Jun 22, 2006
    Thanks guys. All these info is good to know. :)
  11. 94rt10ohio
    94rt10ohio Full Access Member
    982
    May 22, 2006
    Curtice, OH
    The issue you are talking about is with the door seal. Look towards the bottom of the seal near the front quarter panel. If you watch as you open the door it will catch the rubber, causing the rubber to rip. If you have a 04 or 05 5000+ miles, it will be ripped.
    The new design prevents the door from catching the rubber. Covered under warranty. Just make sure to ask for the new design. When I took my 05 Hemi in they tried to put the original design back on! Must have had some old stock they wanted to get rid of.
  12. azpyroguy
    2,089
    May 18, 2006
    Beyond the Sun....
    My insurance is not too bad..especially here in Arizona which is reported to have the second highest insurance rates in the country... I pay about $678.00 every 6 months, which also includes $126.00 to cover my trailer, so my rates really are only about $550.00 every six for full coverage on a 2006 QC.
    Scott.
  13. Chuck B
    Chuck B Full Access Member
    1,309
    2
    Jun 3, 2006
    Phoenix, AZ
    I opted to go with no insurance....much cheaper so far! Az requires a simple bond placed in lew of insurance.
