- Joined
- May 13, 2010
- Messages
- 323
- Reaction score
- 0
I installed B&B headers on friday and ran open headers to the shop...wish it was legal to run it like that all the time...but anyway. The steering shaft bolt is rubbing the second tube. Has anyone had this issue and what did they do. Also....while installing went with the specs per B&B for 35ftpnds and one of the bolts snapped. Got it out fine but just snugged everything down to about 25 in fear of doing it again and not being able to get the stud out. Second issue. I have headers to cutouts to JMB pipes back to magnaflow cat back. The way we did it is cut about 9 inches out of the JMB catback from where the headers line up at the flange and welded a flange on each side of the cutout (so when i go for inspection i can bolt in some fake cats) as well as a set of flanges close to the muffler so that the mids are completly removable. Everything is in there good but im getting a few leaks at the flanges where the gaskets are. any suggestions get these leaks out???? is there a gasket sealer or silicone that will stand up to the heat and people have used so that it seals really well? Also my people running B&B did your exhaust get a little quiter, louder, deeper with the install of the B&B's. My exhaust has a lot less drone running the B&B headers to the factory exhaust manifolds. Seems a little quieter but a little deeper!
