06SRT10
My 10 will run fine for a while then the engine will stop, like I turned the key off. It won't start unless I turn the key off & on several times quickly. Then it will start, but the check engine light will be on. It will run for a while then it will stop again. Repeat over & over. Had a mechanic check it out. He said the code is P0320 & it needs a Crank Sensor. Then he tells me along with two local dealerships that they make a Crank Sensor for a Manual, but not an Auto. Lucky me I have an Auto. Another dealership said it might be a Knock Sensor ($80.00) or a Cam Sensor, no one has Cam Sensor because they are discontinued. Any suggestions.
