FlyingLow said:Yes it is.
Do you see any metallic flakes in it? What does it smell like?
I would also suggest that you have someone look inside that cylinder with a borescope.
FlyingLow said:Is this something easy to do or do I have to pull parts of the engine off?
SilvrSRT10 said:I think it's too much of a coincidence that it happened on #3. I'm no expert but I think it might have leaned #3 just like those with the STS before him but not to the extent of cylinder or piston damage. I think the plug electrode got hot enough that it either curled or pressure caused it to close (somehow). If it was a piece of carbon, a pressure check will tell you cylinder and valve condition. The tap you hear could be the carbon stuck to the valve seat. Just some thoughts.
Yeah, That makes sense. I'm sure the spark plug misfireing is what threw the code as well. What we are all scratching our heads about is what cause the electrode to bend. Hopefully it's as simple as the carbon thing that is now causing the tap noise. But I'm still concered about it being #3 too. Scotts going to have to dig deeper and let all us couch mechanics know.Silverback said:Cylinder pressure would not bend it. Reason for this is that the pressure is equal on all surfaces of the electrode. Therefore you would not have a positive pressure side to cause the bending.
Make sense?
I'm sure the misfire code was a result of the gap being closed on the plug. When that happened that plug was no longer firing, hence the code.
REOMOTORS said:It's pretty simple. Get the engine warm, just let it idle for a while. Take 1 plug out a time and screw in the flexible rubber fitting (metal ends) to where the plug goes. Disconnect fire to the plugs. You do NOT want to run the engine with the compression gauge attached.
Used to be, you'd just pull the coil wire, that obviously isn't the case on this engine. I am scrambling to get out of town, otherwise I'd go look at my truck on how to do this, I'm sure someone else will chime in on how to do this.
Have someone crank the engine (without firing) with the gauge attached to each cylinder. Make sure the throttle body butterflies are held wide open while cranking. Write down the numbers. They should be withhin 10% of each other.
The idea of a leakdown test is a great idea, but requires other tools. Not too tough, but maybe best left to someone else.
Good luck.
viprtek said:The ASD relay in the PDC under the hood. If you can't find it let me know and I can post a pic.
FlyingLow said:A pic would be nice cause I don't know what/where that is located. So let me get this straight. I have to remove all the spark plugs and then just hook up the compression checker. Next I just crank it a few times to get the compression. Should I do all of them or just the odd side?
viprtek said:The ASD relay is in the PDC. The PDC is located right in front of the battery. Take lid off and it will list all of the fuses and relays by a number. It will have a picture on the inside of the cover that will show were it is. The ASD relay is located in cavity # 57.
http://www.vtcoa.com/forums/attachment.php?attachmentid=10796&stc=1&d=1172431905
