yellowfever#154
JMB catless mids and VEC III, I will eventually buy a A/F gauge after I decide which one to buy. Do I need O2 sims in the original 4 locations with this setup?
moparracing said:you guys without cats need sims or you need a pcm flash to eliminate your cel.....
mechanical sims are different from electrical..... with mechanical, you install the mechanical sims in the back two o2 sensor positions, then install your o2 sensor into the sims...... see pic in link:
http://www.s2ki.com/forums/index.php?act=ST&f=133&t=229959
i used the #42002 part's from any local parts store for ~$6.00 a packet (you need a packet for each side)....... from each of the two packets, you need to drill out one of them with a 1/2" drill bit & install them like in the pics in the link above.... you'll probably have to unplug your battery to clear the code (~30 mins) & some driving time may also be involved to clear the code.....
what they do is remove your o2 sensors out of the exhaust stream enough to fool it into thinking there are cats...... work great on my system for over a year.........
you could also strap the back o2 sensors to the frame, but this wouldn't be my choice......
msdnga said:Yes, the SCT turns them off.
you only need sims for the back two o2 sensors........ leave the front two alone....yellowfever#154 said:I just grabbed my bag of bolts that came with the mids to measure them for another member and I noticed that JMB sends 2 of those adaptors with the pipes already. Guess I should have looked at the directions and would have noticed that they came with. Am I going to need to get 2 more for the other 2 sensors?
thank you !Yellow venom 366 said:SCT turns off REAR sensors! You gotta keep front ones in for all systems by my understanding!
Very well said there "moparracing" Two thumbs up!
msdnga said:I actually nailed my tune on my Ram and turned off the front ones also. Not for everybody though....
How is this? I plugged mine in but the CEL had gone (comes and goes). It's definitely the 02s. The truck has catless Billy Boats. Does the light need to be on for the SCT to "find" the problem? Any chance of a brief walk through? I feel like a dumb ass as it's probably very easy lol. Not sure how Moparracings one works by drilling the OEM senors and apart from that it's bung up the exhaust with 18mm plugs and cable tie the sensors to the frame (which is what Sean @ Roe said to do).msdnga said:Yes, the SCT turns them off.
Thanks. I just asked Sean. The CEL light hasn't been on since I put one of his tunes in so touch wood it's been cleared. I'm guessing, when you say: "program loaded" that this includes/means it's part of the mods list? Meaning I gave Sean a list of mods which included catless mids etc so therefore he should have included in my tune the "code" to turn the CEL off?FlyingLow said:If you have a SCT you have to get the program loaded to turn off the sensors. The SCT can clear the code but you will continue to get the CEL until you get the new program that turns the sensors off.
Carlwalski said:Thanks. I just asked Sean. The CEL light hasn't been on since I put one of his tunes in so touch wood it's been cleared. I'm guessing, when you say: "program loaded" that this includes/means it's part of the mods list? Meaning I gave Sean a list of mods which included catless mids etc so therefore he should have included in my tune the "code" to turn the CEL off?
apparrently, i wasn't clear enough for you to understand.......Carlwalski said:How is this? I plugged mine in but the CEL had gone (comes and goes). It's definitely the 02s. The truck has catless Billy Boats. Does the light need to be on for the SCT to "find" the problem? Any chance of a brief walk through? I feel like a dumb ass as it's probably very easy lol. Not sure how Moparracings one works by drilling the OEM senors and apart from that it's bung up the exhaust with 18mm plugs and cable tie the sensors to the frame (which is what Sean @ Roe said to do).
