The one I have doesnt seem to work with this belt...:dontknow: .....
...:argh: ...
TNVIPER said:Dang it.....I was about a mile from home when I punched it in 2nd gear at about 30mph....tires blazed squeeled for mercy putting a big smile on my face....till I let off the gas and noticed the steering felt funny...:argh: .........amazing how fast a temp gauge can climb when you are trying to make it home.....and the steering...the steering wheel was cracking & popping as I negotiated the turns...mainly because it took all i had to turn the thing......came to a 4 way stop and the engine quit...temp was at 250 and climbing................pulled off and sat for 30 minutes.....did a last rush up hill all the way home for about half a mile............![]()
GADodgetech said:
I hope that motor is okTNVIPER said:Yeah...I was amazed at how fast it climbed...went from 180 to 250 in less than half a mile.....when I stopped I got out and turned the pump pulley to try and circulate some water...
GADodgetech said:I hope that motor is ok![]()
Thats good, What cause the belt to pop off?TNVIPER said:Restarted and sounded fine after I let it cool down to about 210....surprised it did not get over 230 on the last leg home...almost half a mile...
GADodgetech said:Thats good, What cause the belt to pop off?
Did you see how black viper has his pulley set up? Is that the same as bone's?TNVIPER said:It never got into the red mark on the guage but was about to go onto it...went to 260+ when I turned the engine off but cooled down when I started spinning the water pump pulley..
I think it was just the fast rev of the engine then abruptly letting off the gas.......the SC pulley is far up from the other pulleys....probably need another tensioner like Bone has or maybe try a shorter belt...that belt only had about 2000 miles on it...![]()
GADodgetech said:Did you see how black viper has his pulley set up? Is that the same as bone's?
glad ya didn't hurt your motor........TNVIPER said:It never got into the red mark on the guage but was about to go onto it...went to 260+ when I turned the engine off but cooled down when I started spinning the water pump pulley..
Bone said:top views
It is a solid piece vs. stock open piece in the middle. Enabled an extra tensioner. Bought the tensioner from Sean Roe. He may still have the bracket design? Maybe fab one up for you? It was based on his first SC try.
He's in today.TNVIPER said:Thanks Bone!..I sent Sean an email. :rock:
