I need to compare a reading....:itsme:
Bone said:Yes. I have a couple of scanners too. What do you need?
I bet you are looking at TPS.
TNVIPER said:I need to know what the ScanGuage reads for throttle position sensor (TPS) at idle. I am having a slight lean out on tip in and I am trying to run down the problem. I cant remember for sure but I thought the scan did read zero at idle?...reads 13 now...just wanted to compare....thanks for the help guys..
WOT said:Mine reads 14% at idle. On the floor, it reads 78%.
TNVIPER said:Looks like my TPS is fine....anyone got ideas why if I let off the gas and coast the A/F goes to 12.X...not that 12.0 is abnormal......if I just barely touch the gas A/F instantly goes to 17+ for a couple seconds....going wot does not cause it to lean...just getting back in the throttle normally....just started this a few months ago..
Odd thing is the my dealer put it on the StarScan and found the MAP sensor had no voltage...inspection found a wire had broke....didnt help though once it was fixed....I am also wondering why it didnt light up the CEL..:dontknow:
WOT said:How do you know your AFR is going to 12.X? Do you have a wideband installed?
i dont have a ROE but my a/f numbers are Crazy, when driving around town there between - 13.2 and 17 bouncing all around at WOT it 12.2 to 12.9 sometimes at WOT it 13 13.2 at top end
