If you are looking for a nice ET then its all in the first 300', particularly the first 60'. So traction play a key role and figuring out how to get all the hp you can to the ground. You also need to be able to adjust your launching technique for track conditions.
Since you have a QC, your technique are going to be a little different than in a RC.
If you have stock tires, lower rear tire pressure to 22-24lbs (Dont forget to fill them back up when you leave the track)
Raise front tire pressure to 45 lbs (Lower it back to 38 before you leave the track)
Drive around the water box but still do a small burnout to warm up the tires and clean them off.
There are two yellow staging lights, pull up slowly until the first one lights up, then creep up with your foot on the brake until the second one lights up. For the basics we wont cover deep and shallow staging
Once the other car is staged then the tree is active and in about 2 seconds it will start the timing sequence. As soon as you see the last yellow light up, GO!
For the QC, would guess you would launch around 1800 rpms and then roll into the throttle. Each QC is a little different (mod depending) as well adjust for track conditions.
