hello all need some help finding some drag slicks or drag radials that will fit on 22s or what would be acceptable so I wouldn't have to shave the calipers any help would be great thankyou
bee0912 said:Also think about this at the track with DR you can run with the street tire cars!:rock: with DS you have to go with the big dogs running slicks?
so when you do get some track tires think about who you want to run with?
depends on the track and or the event.....bee0912 said:Some one please correct me if im wrong? Thanks
mmmmtorque said:The easiest and most affordable route is DR's... They should be fine for your performance mods.
If you want to run slicks you can:
a: Spend 12 hours grinding down your rear calipers to fit a 16" rim with slicks. b: Purchase a DTS rear end through Stinker ($4.5k range installed)
If you want to run DR's.
Just order them (and rims ) and bolt them on.
