tried to post this in the dyno section:dontknow:
i'm new to dynoing...from the videos i have watched the engine runs up and then shutsdown. what causes it to shut-down? a predetermined rpm setting? rev limiter? does the operator control this? i have the stage 2 flash and the rev-limiter has been "upped" to 6200. i'm a concerned about running the engine up this high after reading what could happen.(sean at roe said "if you want your engine to live a long life,keep it below 5200 and 5000 would be better") do i need to run it up this high(6200) to get the numbers? doesn't hp and torque fall off before 6200?
