emblems?
STOCKSRT10 said:
whats a easy no scratch method of getting the emblems off
Go pick up a bottle of emblem remover from your parts store.
dribble some on and let it set for awhile. Then take a piece of fishing line or dental floss and go behind the emblem using the 'string' as a saw. Going slow, it will only take about 5mins.
I'm still waitin on my replacement for the front grill......I can't wait to get the last of the Dodge emblems off:rock:
Yup, use a hair dryer or a heat gun on low and some fishing line with a touch of patience.
It's an elbow grease job. Don't know about the 04s but the 06 SRT/10 emblems are stubborn bastards. :laugh:
what about the rams head on the grill ( just the chrome part comes off right? ) i want to take mine off i got an idea, i havent seen before:D
The Ram's head on the grille is a weird emblem it is one piece but is snapped into another piece that is embedded into the grille. The emblem is not glued but has little tiny plastic nubs that snap into the grille. The chrome ring around the ram head is attached and don't pull it!. Use a small flat head screwdriver (or similar item) and pry under the ram's head and at the bottom of the ram's head. This should remove it. If you pull on the chrome part around the top or bottom yours will break just like mine did when I pulled to hard on the chrome plastic surround. Good Luck! Once the emblem is removed there is a plastic area in the shape of the emblem that sticks up. So if you plan on putting something on top, get your dremel out!
