Engine Stumbles Occasionally...
azpyroguy
Beyond the Sun....
Anyone have their engine occasionally stumble...
Its very random, and only happens at idle... I will be sitting at a light, and it will act like it want to die but only for a split second.. then its fine... does not do it all the time...
No codes set.
Thinking maybe: IAC valve going bad, TPS going bad, or got ahold of some shitty gas.
I had thought about picking up some fuel injector cleaner and running that through a tank or two..
I noticed it after I got gas about 3-4 weeks ago at QuikTrip...
Sounds familiar. I seem to feel something different while stopped at random times also. By the time I look at the tach everything seems normal. No idea what happened. I just figure it is the nature of a the V-10 beast. No idea but it sounds like you are not alone in this.
Same here.. by the time I get to look at the tach... its back to normal... maybe it will throw a code sometime I can can diagnose it....
It has happened to me 2 times. 1st time after installing the K&N CAI and the second time it happened was when I just started the engine and went up a steep driveway. Both times were only a split second but very noticeable.
Going by what I am reading... sounds like this a normal occurance.. being that its happening it different years of the truck... as wyoramsrt-10 said.. maybe its just something to do with how these V-10s run...
Scott.
Scott.
Mine has actually stalled 2 times this month:dontknow:
The dealer reflashed my computer and installed a new TPS for mine.... Mine would stumble, and even stall, at the stop lights. Never had an issue since. :dontknow:
hahaha, 4 and i am just getting started :D :D :D :D
My idle feels rough at times too ... read in a magazine regarding the new viper engine that one of the improvements on the engine is the smoother idle so looks like a well known trait.
