P0456
P0456 Very small evap leak. Could be many things. In a nut shell you are leaking a very small amount of gas fumes into tha atmospher. Your gas cap O-ring may have a tear or not fit right, gas cap loose, Chrysler products ars bad about hoses to canister having cracks. There should be a hose under the hood that has a port with a green threaded cap on it , not sure where its at (My 10 is at home), this is the port we use to pump smoke into the system and look for leaks. The hoses here also split, use a mirror and look under hoses also.
