I went back and looked, we sold you some springs in 10/28/09 and if I remember right you said they were wrong, that I sent you something that wasn't, so we sent you another set of front springs
U send me RC springs that where cut rings off ! ! !
No wonder my truck hanged with the front lip on the ground....
sorry for saying they where not good:rofl:
03/09/12 we sent you the air bag kit since you had such a load on the rear, and yes it does matter how much weight is in or under a vehicle be it front or rear.
Few weeks ago i tested it with the propane tank out of the truck , and still the same...
I have yet to find the shocks or the lowering kit, its impossible tho for me to remember every single order over the years,
but never the less either way, if you are bottoming , which I warn all of our customers the extreme kit may do, I suggest you try another venue.
we only make the two kits, shocks make a mild difference, have you checked to see if there bad yet? if the dampners are bad it could contribute, but without the truck here in front of me there is not much I can tell.
I will say about 90% of everyone that has purchased the xtreme kits, don't complain, all the kits shocks springs are all the same, not very much difference in any of the kits,only a very few will complain they hit, and usually its on rough roads, or big dips,
I designed the kits to what the customers asked for years ago, I took what everyone asked for and we supplied it. If you are not happy with it, then I suggest you look elsewhere.
and yes you may post up what you want in my section or any other, I only check in once or twice a week, so contacting me email or phone, is usually going to get a reply ten times quicker, since soon I probably wont be checking in here at all.
i post here not only for you to see , also for seeking problems solved with other SRT enthousiasts , you suggest only for look other vendors...
