FATJACKS 7.45 RUN!!!
Yes there are caltracs on his truck :)
I love watching that video. I probably watch it at least once a day!
Nice run Jack.
DTS style, good axles, Detroit locker. Had a local shop cut off the end caps on the diff. and replace with the 4 bolt style ends. Still having problems with wheel hop, think it has something to do with pinion angle.
I think you need a 4-link! truck is to heavy for a BIG launch! The 4-link will be more stable. just a thought.....
0 degrees, I understand it needs to be 5 to 7 degrees negative.
0 is good but I like about 3 degrees negative. 5-7 will give you harmonic vibrations that'll vibrate into the cab.
Wheel hop is likely in worn shocks or incorrect shock settings. Still have the kicker shock on dts axle?
Jack, I'm genuinely surprised you would let something small like that hold you up.
