There are three bushings inside the transmission that the shift rail sit in. These bushings will be your problem, switching to ATF may help but if not the trans will have to come apart.
If your shifter is stiff even moving side to side in neutral, your troubles are the bushings I talked about in post 4. No clutch bleeeding, shifter replacement, etc will solve it dont waste your time doing that stuff.
