Front Rotor Question???????
If ya still on here Shu dog, give me fifteen minutes and I'll tear mine down and let ya know, but remember, all rotors are different , but it will be summin to go by
How do you figure? I thought all the front rotors would be the same for MIN TH?
I read 33.9 and i think brand new is 36?
Damn if the fronts differ i may as well pull the truck in this weekend and check. Hopein i was gunnah be alright.
All front rotors match up with all years though right?
Thanks for the work.
SHU
SHU
I missread somthing in the manual, I would guess they are all the same, it doesnt specify in the manual , just says the minimum thickness is stamped on the inside of the rotor
I got 12,000 miles on my 04 and still have stock pads, with plenty left, and the rotor measures 36mm
OK much better.
I think i gottah get mine mic'd anyway so gunnah tear down and have em checked. This will be turn #2 and I don'e think they will be worth turning since i have 60K miles on them and they are pretty bad on the vipbration/warping.
I'll see how bad they are. But i am pretty much thinking i need new ones. It's winter anyway and not much driving here.
Hell this keeps up i won't be makin the AZ trip next week.
SHU
Again thanks for the photo and work.
haint no prob bro:D
as heavy as those bastards are, you might want to try and get a set of the EBC drilled and slotted;)
Shu-Dog,
I've got just over 50K on my truck and have turned my rotors once. At turning my rotors were right at the min thickness and that was some 15K miles ago. I just put new rotors on the rear and will be putting these on the front...
zeckhausen
