FS: Parting out 05 QC SRT-10: Trans, Suspension, Wiring, Wheels, BORLA K+N, etc
Updated list, more added at bottom, sold parts removed:
-Front Frame Section $300
-Hood $400
-Hood scoop insert $200
-Grill shell with chrome bar grills $200
-Trailer hitch $75
-Bed (really nice with tailgate) $1000
-Rear steel bumper $50
-Front steel bumper $125
-Front fascia $250
-Passenger side doors $150ea
-Front pass side spindle $175
-Front Brake caliper set $375
-Wheels 2 nicest $300ea, other 7/10 condition $250 (3 left)
-Radiator $150
-Radiator fan assembly $300
-Power steering line set with cooler $100
-AC comp $75
-AC line set $50
-Spare tire 20" $75
-Auto trans, no known issues, lot drove great $1000
-Front sway bar $30
-Engine harness $300
-PCM w/matching skim/key/cylinder $600
-Borla catback $650
-fuse box/engine bay harness with fuse box $250
-front fenders $150ea
-PS tail light $30
-front fascia scoops $30
-Front fascia bottom shield $150
-trans cooler line set $25
-kickdown cable $25
-DS airbag $75
-PS airbag with SRT-10 cover $125
-RBQ 6 disc radio $175
-Sirius antenna and box $30
-Steering column $50
-Overhead console $20
-Pedal pad set $30
-Speaker set, missing one 6x9, no sub $30
-Factory sub box with grill, no sub $50
-Steering wheel, 6-7/10 condition $30
-Emblem set, 2 Ram, 1 ram head, 3 SRT-10, $30
-Multi function switch $35
-Rear seat $150
-Rear seat storage section $100
-Instrument cluster 137K miles $150
-Radio bezel $100
-Stock catback with QC pipes $100
-Door panels (no DS front) $50 ea, $125 set of 3
-Fog light set $45, one oem one depo
-Power pedal setup with switch and motor $100
-Front coil spring set $40
-Brake boost with master cylinder $50
-Airbag Clock spring $60
-Stock amp $15
-oil temp gauge $60
-stock piston set, one has blems on skirt $150
-PS power and heated mirror $35
-Stock cam light surface rust $40
-stock valve set $50
-Stock lifter set $50
-stock balancer and pulley $20
-Stock t56 bellhousing $125
-stock tb body and blades only, no shaft $20
-Stock injector set $125
-stock flexplate 48RE $100
-Stock QC block spacer set $50
Do you think the Borla catback could be modified to go on an 08 Ram 1500?
Spare tire sold
Also have a starter, dipstick and tube, coil set, motor mount set, and oil cooler with lines
ABS Module
Do you have the ABS Control Module 05142869AB from this truck available? Thanks
-Hood $400
-Trailer hitch $75
-Front fascia $250
-Radiator $150
-AC comp $75
-AC line set $50
-Front sway bar $30
-Borla catback $650
-fuse box/engine bay harness no fuse box $180
-PS tail light $30
-kickdown cable $25
-DS airbag $75
-PS airbag no cover $70
-Pedal pad set $30
-Rear seat $150
-Stock amp $15
-oil temp gauge $60
-starter $80
-coil set $50
-motor mount set $50
-oil cooler with lines $125
thanks for the parts Justin, i wish i had noticed the stupid way the factory attached that radio/heater bezel to the center panel. was going to get the silver one hydro dipped in snakeskin but i don't know how i will get it re-attached. and the srt10 bar for the pass airbag is even worse, come on Ma Mopar think when you put something together
anyway, thanks again, definitely have a use for the line lock:driver::driver:
We have painted them but never dipped them, they are a pain.
Bed, tailgate, power pedals, hood and all wheels sold
