mr. anderson
Some discussion came up in another thread that went away, I think it's good info so I made a new post.
Here's a little info for you fellas that are going to increase the size of you fuel injector and would like a little info.
There are two basic measurements that have to be taken into account, since were talking american muscle I will go with Standard for the measurements. first measurement, pressure or PSI. this is the line pressure on your fuel system. all vehicles generally run a different pressure our trucks happen to be 58 PSI +/- 2PSI nominal.
fuel injectors as a general rule of thumb are rated at 43.5 PSI
the second measurement is flow rate or pounds per hour (lb/hr) rate generally if there isn't a pressure associated with the flow rate the injector was rated at 43.5 PSI.
this is where it can confuse some. since our fuel system doesn't use 43.5 PSI it changes the flow rate of the injector. the flow rate is directly proportional the increase or decrease in line pressure(PSI), since ours is rated at 58 PSI we essentially increase our flow rate of the originally rated injector at 43.5 PSI.
here is an example. lets say you have a 60 lb/hr injector, this being bought from a mass vendor like summit or jegs, whatever. that 60 lb/hr was rated at 43.5 PSI. now since we are putting that injector into our trucks with the increased fuel pressure from standard it is equivelant to 69.2 lb hr injectors @58 PSI.
you can also do the conversion with any simple conversion search on 'fuel flow conversion calculator'
here's one, any will work to get you into the ball park, scroll down to fuel flow calculator:
http://www.deatschwerks.com/catalog/fuel_calculators.php
The key thing is to check both rates when buying injectors, both flow rate and what the flow rate is referenced at, 43.5 or different. ie this injector is rated at 69 lb/hr @ 58PSI
there is also injector impedence. I will discuss that at a later time just know for now there is high and low impedence injectors, there is a difference. both have their positive and negatives. and definately have their applications dependent on what they're gonna be used for.
duty cycle is also important, as a rule of thumb you do not want to exceed 80% duty cycle of the injector, this gives fudge factor for the different temps, and baro pressures.
hope this helps.
anything else, ya'll are free to comment and share the wealth of knowledge. I know there are others that have learned the pain of the fuel system with the increase in power.
hope this helps.
