gatorowned
I did some searches...and did not see anything similar.
I went on a road trip for the first time with the truck. Drove from Jersey to Florida. Drove and handled great on the way down. Averaged 18mpg whole way (occasional 20mpg). I got to Florida...no issues. My problem occured the day prior to leaving. Felt like the truck was not as responsive. Didn't think much of it....and headed back. On the way back I noticed the same thing on the highway. While driving with cruise control on at 80mph I only had about 1/2 inch of pedal to the floor (never noticed that). When I mashed down on the pedal...it would climb ever so slowly. Again...weird. So I pulled off for gas and decided to check. Sure enough...the IAT sensor was out and sitting beneath the intake. I put it back in....took both neg/pos battery cables off and touched together (to reset PCM) for 15 seconds....then drove off. Noticed it was doing the same thing. Just doesn't seem as responsive at all. All in all...I have no idle issues and/or driving problems...just a general feeling like it is not as responsive. When I got back to Jersey...I looked at the gas pedal and noticed it looks lower than the other pedals. When idling...I have only about 1 1/2 inches to the floor. I don't remember it being that way. When I checked the accelerator pedal cable....it is hooked at the TB and cruise cable hooked too. I cleaned the IAT sensor...cleaned the IAC (after finding it) and cleaned the TB with Seafoam.
Bottom line...the truck just doesn't feel as responsive when I get on the pedal. Almost like the accelerator doesn't go all the way down. But when I go and manually push the TB butterfly open...it sounds fine.
Has anyone had the same issue?
