FSTJACK said:The change to 4.56 gears will lessen the wheel spin issue.
You will have less wheel spin with the lower ratio gear.
It is also harder to break the tires loose with a numerically lower gear ratio.
You will be using HP to acelerate the vehicle instead of trying to do it with touque.
With a lower gear the tires will "turn over" and not spin as violently out of control as with a 4.10 or higher gear.
This is a very common misconception that has been going around for years.
Is that right, Jack....................???
Please explain to me how "turn over" practically equates to better bite please.... How is "turn over" different and why doesn't a lower gear spin as much.....
This has got me baffled as hell..........
SD
