Venom Power
Okay guys I had to bring this up. To start off with my odometer currently reads 31925 and I still have the stock clutch. Yesterday I was on the freeway on the way back from work. I remember down shifting to 4th to pick up speed to get around some slow movers before getting off the freeway. Well, when I tried to get her back into 5th it would grind a bit. I noticed I couldn’t get it back into 4th. So I put it in neutral and let her coast off the freeway. When I slowed to about 10 mph I was able to put her in 1st and go through all the gears just fine. Also, there have been a couple times in the recent past where the truck would fall out of either first gear just at take off or reverse. I already KNOW the clutch has to be changed… Boomer has it on the way. But would anyone say that either my transmission or slave cylinder are going bad? If it’s the tranny then I can just take it to the stealership under warranty and have them install the clutch with all the bells and whistles. Has anyone seen these issues with theirs?:dontknow:
