HEADS OFF
Discussion in 'General Discussion' started by Kiwi SRT10, Jan 21, 2021.
Car Parts
  1. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    AMS3 and Kiwi SRT10 like this.
  2. Kiwi SRT10
    Kiwi SRT10 Well-Known Member Supporting Member
    967
    1,000
    Dec 16, 2019
    New Zealand
    Hey Ronnie ya steering wheel is on the wrong side hahaha
    rottenronnie likes this.
  3. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    It's just the reflection from the nearby fence.
  4. Kiwi SRT10
    967
    1,000
    Dec 16, 2019
    New Zealand
    She is lookin' good Ronnie.
    Any under hood pics
    AMS3 likes this.
  5. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Thanks;
    Nothing special to look at under the hood other than taller valve covers because of the valve cover spacers because of the rocker gear but I'll see what I can dig up for photos.
  6. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Looks like many others on the outside. ;)
    Kiwi SRT10, Srt10650, GSJake and 2 others like this.
  7. AMS3
    AMS3 Well-Known Member
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    LOL! That'll do the trick!
  8. AMS3
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    Clean engine, you take good care of it. Question: Can you take a photo of the header clearance on the drivers side at the steering knuckle, and one for the passenger side where the harness has to be ziptied away from the header? I remember someone saying a harness has to be moved on the passenger, and the steering knuckle bolt "hits" the header? And another question: What does the outboard cable on the throttle linkage do? It doesn't move when I open the throttle. The top one moves at the same time as the throttle cable, so I know that's the tranny cable. Could the cable possibly be a kick down linkage? The cable routes into the left fenderwell it seems. The reason for the header photos, is so I know what needs to be done when I finally get my Billy Boats
    Kiwi SRT10 likes this.
  9. AMS3
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    Your truck is super clean, looks great!
    Kiwi SRT10 and rottenronnie like this.
  10. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    My "real camera" in the house is AWAL, and the pics I just shot with my phone are Gerschtunken, so... your questions answered, in order:
    • The BB #3 header pipe will likely hit the bolt on the steering knuckle. The additional length of that bolt can be trimmed (hacksaw) then ground or filed flat without concern. It is soft metal (as many steering components are). Just trim the part that sticks out (easy to spot as the bolt is "too long"). As long as the "sticking out part" is filed flat, it won't hit the tube when the wheel is turned.
    • The Pass. side wiring harness can get squished between the #10 header tube and the firewall (not a good situation) so pull the harness away from the header with a few Zip-Ties, rope, chain, fishing line, barbed wire or whatever you prefer. It just has to be nudged out of the way and held there.
    • The Outboard cable is for the Cruise Control.
    The Billy Boats are costly but nice.
    I'd use the o.e.m. header gaskets for best results.
    Strongly suggest you get the BBs ceramic coated.
    In spite of their claims, I've yet to see the BBs just "bolt up". Ratchet straps are the best way to convince them to.
    Mine required even more persuasion but as I didn't have a D6 Cat handy, I had to get creative.
    Once they go through a few/several hot and cold cycles they DO relax into position.
  11. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    The Dark Times (during The Borg Assimilation)
  12. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Where all the hard work pays off.
    Kiwi SRT10, Srt10650 and AMS3 like this.
  13. AMS3
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    As usual Ronnie, you are a wealth of info. Thank you, and yes, I'll be getting the headers coated. Just need to get my daughter situated and the tranny rebuilt first...:(
  14. Kiwi SRT10
    967
    1,000
    Dec 16, 2019
    New Zealand
    Heads are off and loose bolts. No chamber leaks just leaking from rear coolant hole externally.
    Apparently no visual signs of anything to worry about and she looks clean. Gaskets were black, peeling some sort of paint.
    Heads are being checked over.
    AMS3 likes this.
  15. Kiwi SRT10
    967
    1,000
    Dec 16, 2019
    New Zealand
    Head bolt torque. Seems to be a wide variety of torque for head bolts. I have seen 65, 90, 105 and 120ftlb.
    Any ideas or is it just a stab in the dark.......come in Ronnie
  16. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    That black plastic "stuff" means your head gaskets are the originals. I'm a bit confused as to WHY they were leaking.
    The new gaskets are thinner and you will pick up around 0.4 of a point; IOW from the original 10:1 to a bit higher than that.
    Using the proper sequence with new head gaskets:
    #1 to 30 Ft. Lbs then
    #2 to 90 ft. Lbs.
    The upper 11mm bolts are torqued to 95 INCH pounds.
  17. Kiwi SRT10
    967
    1,000
    Dec 16, 2019
    New Zealand
    Yeah man
  18. Kiwi SRT10
    967
    1,000
    Dec 16, 2019
    New Zealand
    Just getting ready to go into town and see her with the heads off
    AMS3 likes this.
  19. Kiwi SRT10
    967
    1,000
    Dec 16, 2019
    New Zealand
    Thanks Ronnie
    The bolts have come loose. I rang them this morning and that was explained they were not very tight and that some were quite loose.
    I will head off as it is 1200 hrs and I shall be back this afternoon with more news
    AMS3 and rottenronnie like this.
  20. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    The coated o.e.m. head bolts have to go in dry (NO lube at all nor coolant, so blow the holes out with compressed air).
    It is strongly recommended they be replaced after 3 uses.
    They are designed to stretch with the proper torque BUT have a good look at them with a straightedge to make sure they are still A Okay to use again and the thread diameter hasn't pulled "narrower" which would indicate they were over-torqued and should be classed as "junk".
    Again I find it quite odd they came loose.
    Personally, I'd replace them Bud as something else could be going on here.
