Heads
chargerman426
Are the viper car heads interchangeable with our truck motors? I'm thinking about buying a set of used viper heads and having them port and polished.
Far as I know of, it's the same engine :dontknow:
i am actually using a set of viper car heads on my truck right now
Thanks for the reply guys. I'm going to stay on the look out for a set cheap so I can add some more HP without modifying the original heads. One more thing, is it same to assume that because the heads are the same my Gibsen headers would still work with the car viper motor?
On this subject....I have a set of OEM heads from a truck viper engine. Is there an actual "left" and "right" when it comes to these heads? I look at them and can't tell a difference between them.
Anybody know?
just a porting and polishing is not going to get you much ,,,the cost and time ,you wont get a whole lot out of it ,,,unless you go to a bigger set of valves in it the gains are very small for the cost ,,,been there done that ;)
I would have to say if you dont know what heads will fit what engine, or which are which then I would leave the building to a professional, not meant to be offensive at all, but an observation
Who arre you planning on sending them to to have ported/polishhed? Allso what. Iron head is getting at is that you need throw a cam inn there whiile your at it ;) I shouls have your answer soon buddy
Anybody know?
either head can go on either side
Considering I didn't ask if they are different from side that shows you can't read very well...just an obsevastion. If you can't be helpful move along.
There is a local guy here that did my dad's heads for his 340 and is know for his work around this area. I might do the cam down the road but as it is right now I'm not in any rush for heads or other parts as I just got the truck so I'm going to take my time and find parts at the price I'm willing to pay.
Hey buddy let me know about the porting.
My friend has a uncle that owns a engine shop in westminster.
trying to see if he can do some head work for me.
the one person asked if there was a difference in the left and the right?:dontknow:
you asked if the ones off of a viper car were the same as the ones on the truck:dontknow:
just saying:dontknow:
sorry if I offended you , I think:dontknow:
I asked about the parts because I ran into problems with the throttle body's being different. So before I sunk any coin into some heads I figured I would ask some folks that would know. Don't know how you ment to sound when you made your comment earlier but you came accross like an someone that thinks they are better than others.
Ok shoot me a pm with the shops name (if you don't mind) and your number so I don't ignore your call or text and we can get to gather at some point.
not a bit sir, in my experience I have run into the same problems , and I have learned instead of making my mistakes to examine and ask the technician that I had doing the work, sorry if it came across in the wrong way :itsme:
