Venom Power
OSO said:No have not seen the pics nor did i post mine did you start a thread?
Yes in the media section..
Big Worm said:shoot you damn right I am interested
this is the helmet i got for portland international raceway, has a m2005 rating which they approved :Big Worm said:shoot you damn right I am interested
moparracing said:it really depends on what you're intentions are.... if you go to the webpage of the track you are going to, it should have the requirements needed for the speed you run.... you can always email the track for specifics on which helmet you find & if it's specs pass their requirements...
for me, only going 4 times a year doesn't justify a $200.00+ helmet, if a $60.00 like mine will do..... i can add a link to what i got if you're interested.
if that sa2005 & the extra cost makes you feel safer than more power to ya.Prof said:Have to disagree. If you have to have a brain bucket...get the best and be sure it meets the most stringent requirements.
Helmets are safety items...a brain is a terrible thing to waste.
:rock: :burnout:OSO said:After reading the snell testing procedures the biggest thing that jumped out at me was that (SA2005) has a Flame Resistance Tests .
As for the track i have been using they only require a snell 95 rating to run and it would also appear that the m2005 rating exceeds most track requirements.
So i will still be safer at the track than i was and a hell of a lot safer than i am on the freeway. :rock:
Ironhead said:i have two helmets but i dont see any rating on them ,,they have a DOT tag on back of both ,,were would i look to see rating ,,i have a german helmet bean protector that has a Big DOT stamp on it will this work
Venom Power said:They're not football helmets right? Cuzzz, :banghead:those might not be acceptable.
Prof said:It is a motorcycle helmet and will not be approved at a sanctioned track.
You don't need that if your runnin 14 sec and do gimme that safety crap either because you would wear whenever you drive. :slug:Prof said:Here is a picture of the label you need to have...it is on the inside rear of the certified helmet:
