Kevan
Looks good, Tim!
A couple of questions:
1. Does the monitor only come on when you shift into Reverse? Can you manually turn it on/off?
2. Does the monitor ever come close to the shift lever? Approx. how much distance is there between shift lever and monitor edge?
3. Are there version with higher quality cameras? Are you able to swap out the cheap one for a better camera?
4. Can you do a side shot of the monitor deployed? I'm also curious to see it stashed. I'm also interested in the bracket 'travel' and how it was attached to your "Ejection Port" (that's what I call that little cubby hole).
There are TONS of kids in this neighborhood and with the trees lining our driveway, it makes for some anxious moments every time I back out. For under $200, this might be an option.
Plus, I need something to frame my license plate. LOL
