VENOMOUS1 RACING
OK yall, still trying to fix this gremlin that seems to be electrical or soemthing. I have determined that the power loss I get from around 40-65 MPH has to be a sensor or wiring issue to more than likely the injectors. It seems as if the whole right side will shut off ( causing my power loss problem) and I can barely touch the pedal and the cylinders are reactivated again and the truck takes off? By rolling down my back windows one at a time ( having side exit exhaust) I can distinctly hear the exhaust and cylinders firing pretty good. Well as of last night I discovered that when the truck acts a fool that the right side exhaust goes almost silent as if no combusition? As soon as I give it a little more gas ( barely) it wakes up, cylinders firing, and takes off. Return to about the same pedal as before and it acts up again?
I first was totally determined it was the TPS having a bad spot, but have replaced and no luck. Gone thru the Camshaft Postion Sensor, and swapped a few other sensors with a known good truck and no help!
I am thinking now that whatever controls the right side bank of injectors is acting up, has a wire shorting, or relay tripping? NOt the O2 sensors either as I have replaced them a few times blaning them for this poor running.
It seems as if the ignition, or fuel is cut and with a slight increase in speed it all kicks back in?
Sooooooooooo........WIFEY? ANYONE? What controls the injectors firing besides ECM ( replaced it as well). Again this seems to only happen around 40-65MPH and as you pass 65 it clears up and will not act back up until back around 62-65 and light pedal ( cruising) Speed sensor mucking with things? MAP sensor?
