rhskyoung09
- Joined
- Nov 30, 2013
- Messages
- 18
- Reaction score
- 0
I never had any of them unhooked thanks though much appreciated
Everything is stock besides piston rods nd valve springs, wanted to put new cam in but finances wasnt there lol. All machine work was done professionally. Did replace crank sensor. it didnt help. I got all my gaskets from roe. Had to replace timing cover too which was gna be my cam money. Like i said money is tight for a coal miner these days. All injector are firing right jus a rich mixture on left bank. The cat at 1 point was glowing a lil on left Side
Ill have to get ahold of my machine guy for ring gap but it bored 20 over, nd oil pump was scarred up sum nd i couldnt buy jus the rotors. Thanks mopar lol yes new headbolts nd i live in west Virginia
Cam sensor and fuel pressure checked out good
Wow, you have a difficult truck, haha. Does it have a tune? You try returning to stock?
Yes it does have a tun nd i did return it to stock, im gna run a backpressure test on it sometime this week to check the cats
What is the easiest way to get those bolts out? Cut em? Those factory things jus broke off
Clogged cat was the problem.
Awesome, don't need them anyway:rock:
