mcdoogle1975
Mine did the same with a 3 month old battery. It wasn't starter but it takes a hell of a battery to jump these trucks. I was at Sebring raceway and a BMW didn't come close
Thewelshm
What caused the issue?
Thewelshm
Never had to.......Yet
Found this on another site....
First we need to establish what constitutes a fully charged battery. I've seen no small number of posts stating "fully charged battery will be 12.4 volts".
That is ...... Incorrect.
At 12.4 volts, the battery is only 75% charged. That is correct, a FULLY charged battery at rest with the surface charge removed will be 12.6 volts.
This is because a 12 volt battery is made up of 6 cells, each producing ~ 2.1 volts. These are tied together in series, meaning the voltage of each individual cell is multiplied by the number of cells to get the total voltage of each.
There is a very big difference when a car battery drops even a small amount of voltage. When an automotive battery voltage drops from 12.6 to 12.0, for example, its 'power' drops from 100% to 25%. At 12.4 volts, a car battery is 75% charged while at 12.2 volts its 50% charged. That is correct, at 12.2 volts, consider the battery HALF DISCHARGED.
For simplicity's sake, you can consider your car battery charged at 12.4 volts or higher and discharged at 12.39 volts or less, but 12.6 is 100% charged, 100% rated capacity.
I don't like where this is heading. Try to turn the engine over by hand & Check for resistance. Use a socket & ratchet on the front crank bolt. I know it's easier said than done. If It won't turn the pull all the spark plugs and try again. It should then turn over with relative ease. If not something is locked up in the motor.
You may want to disconnect both battery connections and hold them together for 15 seconds to clear the PCM. Low voltage conditions can cause some erratic problems. You might also remove all of your ground connections and clean the contact areas with a wire brush. A bad ground can cause all the issues that you are describing.
So it starts now? Oil pump is attached to the back side of the front engine cover and runs off the crankshaft snout. You have to disassemble the entire front and drop the oilpan a few inches to get the front cover off. I would check other issues before you dive into all of this. There is an oil bypass valve near the filter - it has a flat Allen head cover bolt holding it in place. You might try that. Dumb question but you didn't spring a large oil leak and now not have any oil in the motor?
