099 FEVER
Member
- Joined
- May 4, 2007
- Messages
- 255
- Reaction score
- 22
I'm hearing valve train noise. Then a little later in the clip I hear a deeper noise like a rod . I wouldn't drive it. Have it towed home remove the nos and plug any install holes. Be sure the PCM is stock calibrations. In order to sleep better use a mechanics stethascope and listen to the valve cover, then the head and finally to the side of the block near the oil pan. You should be able to isolate the location(s) of the noise and have a better idea what it is. Call the dealer to pick up the truck when you get it back to stock and be there when they check it. If they say you over rev'd it tell them you have trouble with the second to third shift frequently. Blame it on the shifter it's a factory problem. Even the SRT engineers couldn't get the factory truck to shift right at Mopars at the strip last year. They know the shifter is junk and causes problems.
