help
I am very pleased with how well they are dealing me in this forum .
good I would love to buy a new clutch kit for srt10 , which recommend me ?, is for normal use without abusing the car.
where they would buy
Hello , I need is the kit clutch my car this series and is normal not use aggressive driving
Miguel,
you can find good parts from our vendors on here, if it comes to ship parts from US to Europe i can help you out.
I do also have some parts in my garage, as i have more than 1 SRT10 and buy all sorts of stuff as i am running also a german SRT10 Forum and help in the european section of this forum.
I can also use google translator to understand everything, if you prefer spanish.
All the best
Arne
hola,busco un kit de embrague nuevo para mi dodge ram srt10 del 2005, el de serie es suficiente porque es para un uso normal , pero di por poco dinero tengo uno mejor no me importa
good luck even though i can't read it, can't imagine how hard/expensive it is over there to work on or buy parts for. at least Ferrari and Lambo have dealer networks over here, no Jegs or Summit Racing over there (for American makes that is)
hello , I seek a new clutch kit for my 2005 Dodge Ram SRT10 , the standard is sufficient because it is for normal use , but if for some money I do not care better one
Miguel,
El clutch Centerforce o Spec (stage 3) son buenos y cuestan tan sólo un poco más que un clutch de fábrica nuevo.
if you have a stock truck and plan to keep it that way, i would recommend a stock clutch. they're made by LuK
if you plan to add any forced induction or engine work, i would recommend a Spec Stage 2+ clutch
i would also just install a new OEM flywheel.
make sure you change your slave cylinder as they are prone to failure and are internal. no sense in putting in a clutch with a used slave (ask me how i know) ;)
