Help
Discussion in 'General Discussion' started by Baggie Austin, Nov 21, 2021.
Car Parts
  1. Baggie Austin
    Baggie Austin Full Access Member
    98
    40
    Sep 3, 2016
    Birmingham England
    Hi all, mad as it gets
    Moved out to countryside and annoyed already.
    Put the truck away a week ago and it was fine
    Looked at engine this morning and mouse droppings on cam covers
    Hardly ticks over, smells very rich, headlights not working , sounds awful
    Can't see any obvious wires chewed
    Anything obvious you think it may be?
  2. Baggie Austin
    98
    40
    Sep 3, 2016
    Birmingham England
    Sorry forgot to add ABS light also now on
  3. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    The little buggers love to chew on wires.
    Each of your issues IS electrical.
    Look around under the Intake Manifold/Blower for signs of a nest.
    It may take some time to find the damaged wiring.
  4. Modern Barbarian
    Modern Barbarian Active Member Supporting Member
    105
    132
    Sep 16, 2021
    Also check your intake box, they like to nest there and the nest can restrict airflow causing a rich condition
    AMS3 likes this.
  5. AMS3
    AMS3 Well-Known Member
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    Hmm, that would never of occurred to me to look there. Good call.
  6. Modern Barbarian
    105
    132
    Sep 16, 2021
    I had some nest in the intake box on my tahoe once. Took me forever to figure out what was wrong.
    AMS3 likes this.
  7. Michael from the U.K.
    Michael from the U.K. Member Supporting Member
    328
    11
    May 22, 2006
    Berkshire in England
    This happened a few years ago,dog biscuits behind the firewall insulation and under the intake manifold,there were so many biscuits the little fuggers never had time to start chomping on any wiring.I leave baited traps in the garage during the winter now
  8. AMS3
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    WOW! They sure can make a mess. Hopefully you can get the wiring fixed and get her back on the road.
  9. Penney
    Penney New Member
    5
    11
    Oct 26, 2021
    Sorry about your luck! Man Alive that suks!
    AMS3 likes this.
  10. 505
    505 Full Access Member
    76
    38
    Sep 7, 2018
    Orlando
    You gotta get on that shyt before they eat the whole truck. I would check your wheel speed sensor lines in front, also look at your wiring going into the PCM all 3 bundles. And if it's an 06 might as well look at that bloody TIPM.
    AMS3 likes this.
  11. Baggie Austin
    98
    40
    Sep 3, 2016
    Birmingham England
    Hi all
    Thanks for the advice and suggestions
    Looking like they have chewed some of the spark plug leads, no other obvious damage
    Suppose it explains the missfire and why it's dumping fuel in the exhaust
    I had activity right at the neck behind the blower, it's perfect in top of the coils for them
    Bad news is I am going to have to remove the blower now and intake to swap over the leads
    Looking at it though it does not look like removing the blower should be that bad
    Is there a how to guide it any advice that may help me with that. It's the Whipple that roe supply.
    Thanks again
    AMS3 likes this.
  12. Modern Barbarian
    105
    132
    Sep 16, 2021
    I dont know about the blower, but for the intake, if it's the stock one, a 12" swivel extension is your friend. You can go through the runner's for most of the bottom bolts. Other wise it's an eighth turn at a time with a wrench.
  13. Baggie Austin
    98
    40
    Sep 3, 2016
    Birmingham England
    Thanks
    I am trying to get hold of jtsvp through their website, however, it's not letting me
    Want some prices on parts
    If you are about please can you message me and I will give you my email
