Genric question for you..
When reading a generic OBDII scanner hooked to a 5 gas analyzer, you notice that the particular car you are working has a high amount of HC's and the car failed emissions yesterday. The customer states that it runs rough at idle, but the car runs well at off idle or WOT operation. Using your scanner you also notice that a vaccum line is loose under the hood, and the Injector pulsewidths are higher than idle operation by 1.2 Miliseconds, and the LTFT is at -6.
What is the problem??? :dontknow:
