Hey guys what is a good choice for lowering kit
Status
Not open for further replies.
Tito#14SRT
Tampa,FL
I got the RC was looking into lowering my truck with either the JTSVP lowering kit or X-METAL what is the difference in height? price?
where can I find an electric cutout 3"? I bought Billy boat headers,catless mids, and catback exhaust.
Thanks
JTSVP can take care of everything you want...I have an X-Metal kit and have no trouble but you will not get any service if you can even buy the kit from them now.
x-metal is crap go with the tony's set up. he make the best one, the actual right spring tension and i think he has two heights available
:dito:
What about just blocks for the back? I ordered the 2" from stinker. Any problems such as brake lines and such?
I have 2" billet blocks on my RC and it sits perfectly level. You do not need to change brake lines or anything else for that matter.
tito jsut for info
this is what comes iwth the kit
ffront springs 10% stiffer than oem, and patterned with the same spring rate as oem, something other manufacuteres dont offer, most use hemi springs in there kits
new front bumpstops
front and rear sway bar bushings
rear solid aluminum blocks , your choice 2.5 or 3 inch
new hd u bolts, nutts washers
thansk for all the kind words guys:rock: :love:
JTS VENOM PERFORMANCE said:
tito jsut for info
new front bumpstops
2.5 or 3" is that for the rear??
If I do 3" inch does that level the truck all around or still keeps a stance being that the front is dropped lower then the rear a bit.
what would be the drop in the front??
Yes, this was prooven by my local suspension shop a couple weeks ago. They had to pull out some BS from under #1900 and replace that sh*t with harder and better materials. To save you from this crap I suggest you go with JTSVP (Stinker).. That drop is hottt..
the three option is for the rear, going 2.5 leaves a little rake, 3 inch make it perfectly level pert near
Status
