Kevan
Hey folks. I'm having an issue with the idle on the truck. Truck is N/A (am I the only one left? LOL) with only JMB CAI and Magnaflow.
When cold, it idles fine (around 750).
After the engine gets up to normal operating temp, the idle increases to anywhere from 1500 to 2100.
- No codes thrown.
- All hoses and connections are tight and clean.
- All electrical connections are tight and clean.
- The IAC has been replaced (and computer-checked at the same time).
I didn't make it 3 miles from the dealership before the idle ramped back up to 2000.
I've found out that if I turn the ignition off, let it remain off for 1-2 seconds, then re-start the truck, idle is restored to 750. This is only temporary. As soon as I get the RPM's up past 2000, the idle will remain high (1800+).
The idle does go back to normal if I let the truck sit and don't touch the throttle. It takes about 4-5 minutes for it to get back down to 750.
Any suggestions before I pull the TB and completely rebuild it?
Oh, and for those smart-pants ready to post, "Just get a new TB, clownie!", budget for this project is less than $50.
- No codes thrown.
