Home A/C help needed ---Any HVAC Techs here
VIPR PWR
Well-Known Member
FL
Anyone on here do work on home A/C units????
A rental house owned by us has a Carrier A/C unit
Model #38yb030300
serial # 2496319513
The fan is blowing downward and forcing the air to be pushed out through the condensor......I was under the impression that the fan should be pulling the air through the condensor and up out the top of the unit ...Which way would be correct???????
Can't say I have seen that before :dontknow:
Not an HVAC tech, nor did I stay at a Holiday Inn last night.
Those Damn Holiday inns will get to you if you stay in them:aetsch: ..
The A/C unit was worked on at some point prior to ownership of the property..... The capacitor went out on it today.... I replaced that ... But wasn't sure if the motor/fan was turning in the right direction .... :dontknow:
I will check with a guy (ownes a HVAC company and works in the field himself) tomorrow if no one posts.
ac condensor
Your ac condensor should be pulling air thru the coils and blowing the hot air out the top 100%.
