hood question
I believe they are mainly for aerodynamics. Too much turbulent airflow through that grill is not good. Also, the stock airbox get all its air from the fenderwell. Much cooler than underhood air.
Yep, I took the after market K&N off about a month ago, and installed the factory set up, with a drop cone K&N filter. Seems to have a tad more response now.
So i noticed there is a plastic piece on the inside of the hood but is only on one side (see image), my question is should there be one on another side? If so, does anyone what part # it is? Thanks.
Welcome the RBC and yes they are 2 of em one on the drivers side and another on the passenger side. Mine had cracked had them replaced from X2 builders.
so i guess that might explain why my passenger side is missing, the person before installed a mopar intake with the cone air filter. Perhaps that part was removed to force more air into the intake? Just a thought.
Anyone know what part # they are? Would like to see if the 05 and 06 are the same or not
05 and 06 part #'s are the same.
